One of the ABB engineers saw something similar in a German Ford plant (Duren?) where the robots were only protected by black/yellow floor markings, when he mentioned to German engineer that would not be safe in the UK the German said "but we are not British" says it all really
yea but u only need some dopey git to catch his leg and trip and before u know it hse and claims direct are down on u like a ton of sh ,.//../twe seam to have got daft at work at the moment putting barriers around pallets not as if they jump out in front of you
when i am in work tonight i will take a photo of the interlock switches on one of the okuma lathes i run. It has been disconnected via a keyed switch, but has also been jammed in the 'door closed' position in order to speed up production. Unfortunately it doesn't as i refuse flat out to open the door until the spindle is at complete stop and i have put machine lock on. This adds about 30 seconds to each cycle, and i have even had managers tell me not to do it. I have always responded with, if the h and s manager will come and run it in an unsafe condition then so will i. Never once has h and s been out to see it.I see more CNC mills with the switches disconnected on the doors than with them still working. You can't see through the windows on a CNC with the windows covered in coolant and need to check the job. So I think it's justified on those.
Scares me more to see injection mould machines with them turned off though. Not particularly highly trained people come in contact with them coupled with anything into the thousands of tonnes clamping force + molten plastic + possible robots = a def H&S issue.
The key/plate on our lathes and mills is held in with a couple of m4 cap heads. We just take the screws out and put the key in the interlock switch. It's no different to operating a centre lathe having the doors open. Still e.stop buttons inside and out on our mazaks and haases.
