Ok so I am going to be gentle here with this post, after all its only common sense really
If this was my welder for home use I.......
I would have an actual circuit drawing of my machine then draw another one according to the mod that I want to make, double or triple check it
I would take current and voltage measurements on all original components, i.e. all inputs and outputs open circuit and under load, to compare after I had done the Mod
I would mount all components in the live side of the welder as it is not easily accessible, I would never mount any electrical components in such a manner that someone or something can touch any live wire or terminal. Transformers are available either "open" or "closed" meaning that one can buy a purpose built enclosure for a transformer. Make sure that the case is earthed using the correct colour earth.
I would fuse the transformer on both the primary side and secondary sides. I would measure the actual current open circuit and under load to ascertain what size fuses you would need, yes it can be done mathematically but there are variables such as motor current draw which can change depending on the load. Usually a PCB will be taken out by an overloaded motor, too much tension etc.
The wires used must be the same diameter as the originals if you are joining them to continue a circuit. I would never put wires through a drilled out hole
where there is a chance to wear through the insulation
I would use a small amount of heat sink grease on the back of the bridge then mount it to an actual heatsink, I have seen bridges blow up. I would not solder wires to the bridge terminals as I have seen heat melt them, they also corrode easily. I would use purpose made terminals, crimped with a proper crimper, With crimp terminals or spade connectors there are two diameters of the plastic part, the bared wire should be pushed in and there should be enough insulated part of the conductor pushed into the first section (larger) and crimped securely, I would place a small capacitor across the bridge to help smooth the DC and it also helps to share the load.
Some people may say that you dont have to worry about polarity in AC circuits. This is simply not true in most circumstances, always be aware of polarity whether it is AC or DC.
I would then go over everything with an ohmeter and megger before powering up, but I would be sure that PCB is not meggered or any"delicate" components.
I would then recheck all my connections making sure that I have made all connections as per my mod drawing
Check all insulation
OK I think I have done everything that I want to do before powering up.
I would then switch on and check all voltages with a good meter.
Then I would bang test it and take all voltage and current measurements and compare with original, I may be drawing a little extra current from the input, so I would have to check that my wiring and breaker are OK
I would weld for a while then pull the plug from wall and check everything for excessive heat, if OK I would continue on welding but keeping an eye on the machine.
I think that about covers it, I may have missed some detail, would be easier if I had a machine here to do the mod on though.
Sounds a bit hard?
I wouldnt want to hurt anyone now would I
Have a good close look at the pics in the posts on this thread
I would do this mod having safety as my main priority, If I was unsure about any aspect of what I was doing I would not attempt to do it in the first place!
Cheers
"Let common sense prevail"
Sounds a bit hard?
Cheers
