rtcosic
- Warwickshire
I’ve never uploaded photos before, so thought I would experiment.
There is even a Welding element - number 3 son and I made the engine storage cradle.
I like shiny bits (and pretty pictures), like these:
I did some Nickel Plating of nuts, bolts and small brackets like these:
However the bit I thought you might be interested in was the use of Electrolytic Cleaning (Derusting) of the larger steel and cast iron parts to prepare for painting.
If you want the theory behind it all look at this set of university course notes:
http://nautarch.tamu.edu/class/anth605/File9.htm
I was setting up my bath to prepare a rusty tow bar for painting before transferring from one Rover 800 to another, so I gathered some MX-5 parts which have found their way into my shed and took photos along the way.
Tow bar super shiny bit:
Two complete front suspension uprights and one scrap front caliper ‘as found’:
Stick them in the magic bath and watch the muck come off :
I deliberately restricted the current to 4 amps, thinking that would be within the capability of the typical small battery charger most folks would have lying around, and left them overnight. This is how they came out, after a quick attack with the pressure washer (The Ultimate Authority was lurking about so the weapon of choice - dishwasher - was temporarily out of bounds):
Low current, large surface area – this is going to take ages. I could reduce the number of components or increase the current. I ramped the current up to around 10-12 amps and left them to bubble away again overnight. Pressure wash and scrub in the sink with a stiff brush (she was still around) and we have:
Notice how the threads are cleaned out – makes dismantling rusty components much easier:
Disassemble:
Notice that the parts are also degreased and that good plating is unaffected:
Non-corroded machined surfaces are unaffected:
I was getting bored by now so only put one disassembled back plate and upright into the bath for the very last overnight session, plus the caliper just to demonstrate that you cannot damage the parent metal by 'overcleaning'. Pressure wash, scrub and VERY light wire brushing gives this:
The cleaned surfaces are very ‘active’ and a flash layer of superficial rust can appear if parts are not dried thoroughly, as happened to one small area of the caliper:
Found I'd done a left back plate and right upright on the second go!
If you like belt and braces you could pop the parts in your bath of Bilt-Hamber Deox-C for the ultimate finish. The bath would last forever as there is virtually nothing left to consume the citric acid (or whatever the active ingredient is)
I have my eye on a 90 litre plastic container with a lid that I saw in Homebase – big enough for a small engine block I reckon.
More links:
http://www.stovebolt.com/techtips/rust/electrolytic_derusting.htm
http://myweb.tiscali.co.uk/andyspatch/rust.htm
http://www.instructables.com/id/Electrolytic-Rust-Removal-aka-Magic/
http://www.antique-engines.com/electrol.asp
http://www.rowand.net/Shop/Tools/Electrolysis.htm
http://www.davidbradley.net/ERR.html
http://www.youtube.com/watch?v=R5I5WBG5HPw
http://www.youtube.com/watch?v=-8vT2mdXBs8&feature=related
http://www.youtube.com/watch?v=jF6nStS3_xE&feature=related
http://www.htpaa.org.au/article-electro.php
Disassemble:
More links:
