phasesonix
I know there's a big price difference and the finishline does'nt seem to have a carbon filter-any other differences??
I too suffer from asthma, but what you said in the first line of your post made me think that I hadn't got myself a good enough, and safe product, but what I do have is enough filter separators from 25 micron to 5 then a coalescing and finally the carbon before the airline, and have filtered extraction even though I'm in the middle of a field
The trouble is that there is no proper info out there as yet on the Vizi only on the MPV, so I gave DeVilbiss a ring and asked, the difference I was told is as Dan says no carbon filter on the Vizi. I was thinking along the lines of getting one of these
http://www.spraygunsdirect.co.uk/product.php?tid=105&products_id=5094
With the Vizi, which would mean no carbon filter needed in the mask, and for a similar price for just the MPV. But as it happens I got hold of some Parker ones to do the job as well as giving you cleaner air going through your gun, but boy do you need more compressor duty to keep up.
thanks for the replies-I bought the mpv off ebay but it was described as new and now I've received it the regulator looks well used plus the 2 carbon filters are nearly 4 years out of date!
I did'nt think much of the build quality though,just a thin plastic mask.
I'm returning this one as there are couple of other "new" ones on ebay-will have to ask lot's of detailed question before I bid though.
loz
Personally I wouldn't buy second hand, even if they do claim it's "as new" the carbon filter only has a 1000 life span and as you've already found out they go out of date too.
I'd go to spraygunsdirect and buy a new one, yeah it's more money, but don't risk your health for a few quid saved.
Do you mean a filter for the MPV or a wall mounted type, as you need a coalescing filter before the mask, and your quite right getting set up swallows the cash for sure. Safety issues aside, Looking at the Vizi air fed there isn't much you get for over a hundred quid really they are making a pretty profit on them that is for sure.
eil's right, a lot of people ask why their simple paint job costs so much money, but fail to realise that getting the right set up for the paintshop costs big bucks.
You should have every conceivable filter system to be sure you don't suffer. if you can't afford it, wait until you can, or do the job with rattle cans!! sounds harsh I know, but you gotta protect yourself.
Another very simple thing people don't realise, make sure your compressor is well away from the paint area, otherwise you might as well not have a mask at all if the comp is sucking paint fumes in.
Can you put the links up phaseonix as them sounds cheap enough, by the way whats the size of the 50M airline.
