Thought ill start a new thread on my attempts of Hydroforming. Got to admit it turned out really well with no creases or bends. Also when doing this the metal will "unbend/overbend" if that makes any sence.
Here is the template, you can see the original lines of where I wanted the pipe to "under/overbend" but I allowed 3/4" each side over for this. The orrange is the cut'off but I changed this before I cut.
This is the modded template, use layout blue then scribed. I got to admit I will never go back to using a marker pen to do layouts as the layout blue is amasing.
The two pieces were roughly cut then tacked together ready for the grinder to get the cut right.
All the edge was folded using a pair of mole grips then slowly pressed together and welded.
Both sides welded together.
Made some connections.
600psi later.
All cut off.
I will do the other side and finish hopfully this weekend.
	600psi later.
	All cut off.
