Carter
Evenin' chaps. Just browsing your threads tells me I've found a forum where I can talk to the organ-grinders instead of monkeys.
Here's one for you.
Bought an old 3rd Gen Honda Prelude (the flat square retro one) for not much at all and on the understanding that the owner and anyone who'd looked at it couldn't resolve the persistent low speed/idle misfire. Turns out that the 20yr old twin Keihin carbs were totally ronnied and Mr. Honda wants £1265
o for the service kits! (no I haven't misplaced the chuffing decimal point either; that's actually what they want to invoice for a fistful of brass 'n butyl!)
There's none left in the scrappies now and even if I could find a pair they'd likely as not be in a similar condition = back to square one in a year or two,... so... in a fit of lager I decided to have a crack at fuelling it via these puppies....
WOOF! a set of mint quad carbs from a Yammy YZF R6, will flow enough gas for 129bhp in the bike so with judicious jetting corrections should be more than adequate to restore the poxy 109hp that the Honda was originally shipped with. It's worth it for the go kart handling believe me.
So the only issue is fabricating the fanimold and induction pipes to mate the carbs (38mm int. bore on equal 72mm centres) to the rectangular offset ports of the Prelude's cylinder head. I had a new aluminium flange jet cut from 12mm plate and tried to go with mitred sections of 40mm diam. ally tube for the runners. The idea was to machine a stub at the end of each one to make the final transition from circular tube to rectangular port. I went for ally thinking it would be easier to deal with having nowt but a Black and Decker Workmate to work on. (I'm not joking here) Well I handed the finished sections to a 'welder' who pretty much wrote the lot off. B*gg**! Odd as well considering his stainless work was immaculate??? I mean even I know that ally is a completely different metallurgical kettle of fish when it comes to welding it. Anyway the whole shebang was as ugly as sin and a gas flow nightmare no matter how much die grinding I might have applied. Pah!
So on to 'Plan B' then, trouble is I can't find anyone who can swage and bend some solid tubing into shape so I thought "can it be folded or rolled up from stainless sheet and simply seam welded? Gotta be the way to go surely, I mean how hard can it be? we've been bending metal since year dot there's got to be someone in this city who can take this simple job on. Er... it seems that there isn't. Well not for the money I've got spare anyway. Looks like I'll have to do it m'self then. I've now arranged access to a workshop/tool room but first of all here's a few CAD screenshots of what I'm trying to achieve.
the moody upskirt shot
The Yamaha carbs are equally spaced but the Honda's ports for the inner cylinders (2 & 3) are offset towards each other requiring the inner pair to slant inwards whilst the outer pair (1 & 4) of runners need to splay outwards slightly as this shot shows.
This is an added dimensional complication but CAD says it's do-able or I just might make them all identical and 'fettle' them into their allotted place and angle of splay. Overall runner length isn't too critical so long as they're all within a millimetre or two of each other.
A few more...
The original ally flange... I want a jet cutter for Crimbo! Note also that the OEM gasket is 'siamesed' as is the original cast manifold. This conversion will restore individual induction tracts which may require some jetting trickery to compensate on the inner pair, s'going to be difficult to determine without four individual Air/Fuel ratio probes welded into the exhaust manifold.??
And a few 'hidden line' renderings...
and...
You get the general idea. So that's where I am at the moment, so I'm sitting here scratching my swede wondering whether it's best to start making templates 'n such. Is there any benefit in milling up a pair of mandrels (it's symmetrical about its centre line) from some engineering plastic I've got hanging about, does it need cone rolling or something? I read Chunkolini's thread and his 'ghetto' folding bench technique and thought aye aye.., that might do it, dunno... where to start or do I just wing it? Any thoughts, ideas, gratuitous ridicule? all is welcome at this point in the bl00dy epic, Christ I knew it wouldn't be an instant fix but sheeesh!
(Carter pulls out last handfuls of prematurely greying hair)
Gentlemen, I am as Prince Charles; .... all ears.
Here's one for you.Bought an old 3rd Gen Honda Prelude (the flat square retro one) for not much at all and on the understanding that the owner and anyone who'd looked at it couldn't resolve the persistent low speed/idle misfire. Turns out that the 20yr old twin Keihin carbs were totally ronnied and Mr. Honda wants £1265
o for the service kits! (no I haven't misplaced the chuffing decimal point either; that's actually what they want to invoice for a fistful of brass 'n butyl!)There's none left in the scrappies now and even if I could find a pair they'd likely as not be in a similar condition = back to square one in a year or two,... so... in a fit of lager I decided to have a crack at fuelling it via these puppies....
A few more...
and...
Nearly dropped me bacon sarnie when he came back with the prices though, £26 for the slab and £15 for the sheet?
I see what you mean about riffling out a circular manifold hole to a rectangular flare. It's a variation on the individually machined stubs/transition pieces I was dreading making.
Other factors? I Can't resist a challenge and I've already had emails from 3 'Lude owners asking if I can knock something together for them as their twin Keihin rigs are approaching a similar state of decrepitude but the cars are so worth saving.
Unfortunately I don't have any workshop,shed/garage space to let me tinker so AutoCAD has had to become my virtual workshop where I test the theory as far as I can before the metal munching starts and for that it's been a godsend. In fact in many ways it's preferable...eg
