shenion
Tool Pack Rat
- Stone Mountain, GA USA
I have used straight 30wt oil on mine. See if you can find non-detergent oil. I use Mobil Vactra and Veloctite synthetic way and spindle oils on mine.
Auto oils have lots of additives over a straight oil. Non-detergent auto oils are supposed to be closer.
My lathe probably never had the spindle pulleys oiled by the previous owner. The oil point looks like a set screw so probably missed. Had to replace the pulley bushings.
I use chainsaw bar and chain oil on the gears. Works well and does not get sticky like lubraplate. 50/50 STP/oil mix is supposed to work well too.
I use indexed carbide tools on mine. Carbide has come a long way in the last few years. I get a better finish on the new carbide tools than HSS. Partly due to the newer coatings.
You can get a holder set fairly cheap (I make mine, takes about 10 minutes.) Insers can be expensive but I keep an eye on ebay and pick up surplus packs of 10. Usually get then for about $1/ea.
Forget the brazed carbide cutters. They are usually very cheap and don't have any relief angle. That makes them require more force and don't work as well on these lightweight lathes.
I try and get inserts with the correct relief angle and a chip breaker. That resembles the desired angles that you are supposed to grind HSS bits to.
