Would like to see him grind galv off chain link fencing!
To braze with Arc you use carbon copper rod and an odd looking device with a slightly different technique to normal Arc welding.
Alex
Why? Would it make your day?![]()
Sorry I didn't see it was chain link fencing, I envisaged normal galv fencing with them funny three pronged spikes at the top.....
Even so, if he only gotta weld 2 links, one at the start and one at the end, wouldn't he be able to put them in a vice and just take the bulk of it off where he wants to weld?
Ive actually got a carbon arc torch, its years old I didn't know you could still buy them, difficult to make a decent brazed joint because the arc is unshielded and you're fighting the oxidation, its a useful heat source though for straightening etc.Hello, just go to your local welding supplier and ask him for a carbon brazing attachment, it looks a bit like a set of spot welding arms. There are two carbon electrodes that when attached to the welder makes an arc that you feed a flux coated brazing rod into whilst touching the part to be brazed with the electrodes at the same time. It is a dubious way of brazing and can be very wastefull of rods and electrodes at times. I have never had a very reliable joint using them and I have tried various types, better using a mig welder, hope this helps, Bob.
nope im cuuting bits offf and making hanging baskets . Been whering basic mask and im ok so far
this is an old post revived :For Brazing Galv Plate, or any other kind of Brazing, one way is with a "Twin Carbon Arc Torch" running from an AC MMA Arc Welding Transformer. You can use DC but the electrodes then burn at different rates which is awkward. It uses copper coated Carbon rods x2. You heat the metal with a flame which protrudes from the arc in a V shape. You apply the Brass Brazing rod to the metal, not the arc, and it will melt only when the metal is hot enough. You can use Flux Coated or Uncoated rods, with a separately applied flux dissolved in water, which I believe is mainly Borax and a colourant. I find this method to be Cheap, Easy, Easy to learn, Zero costs whilst not in Use, (unlike Bottled OA gas), and very adaptable eg to heating for bending etc.
What I want from this or any other Forum is a table of Lens Shades vs. Current (Amps), also typical metal thicknesses, carbon rod diameters, filler rod diameters, etc. etc. but Especially the first two. Surely this info can't have been Lost since the 1960's?!!. You find tables of this kind in every Arc welding book but never for this use. The UV and light output is probably greater than MMA because I believe the carbons (or carbon rods) were originally intended for Carbon Arc Lamps, eg Stage Lighting, Projectors, and the Carbon ends glow brilliant white on their own, over and above the arc itself. I'll certainly post some photos if anyone is interested. There is such a torch and some carbons currently for sale on ebay, quite cheaply.
there was a fair few posts and replies to carbon ark torches and there use . i sold mine to a member cheap as i have no use for one and only bought it to have a go. realy o/a bottles cant be beaten for versatility and use but a carbon torch is the next best thing but cumbersome
