This is so basic it is embarassing but I know you guys have a lot of experience so here goes.
I have started serious metal work but don't have specialist tools. I have hand tin snips for thin steel. I have an old & cheap hand hack saw that allows the blade to wander making straight cuts impossible and both 115mm & 230mm angle grinders. I also have a slide mitre wood type saw that I hoped might be useable as a chop saw but I don't know if there is some reason that metal cutting blades don't seem to be available for this size 255mm with 25mm bore - safety? I also have a 2hp compressor.
The question is where is my money best spent to be able to cut steel.
I want to be able to cut thin steel sheet for car body type work, plate to 6mm and box section/ tube to 75x50mm.
Money is an issue as is storage space.
Chris
Chris
