vr4awd
The Scottish Scouser
Hi guys
i hope somone can help me out here.
im looking for some info on welding gas bottles and also to settle a small dispute over them
these are the bottles in question
and this is a close up pic of the connector and as you can see the cos only has a much shorter valve insert and the mix valve insert comes all the way to the top of the connector valve
and this is my welder and is set up as it come out of the box and nothing has been changed exept for sticking it on a welding cart
do both bottles need diff regulators for them or can you use the same regulator
when i connected the mix bottle and turned on the rgulator and it didnt let any gas out of the bottle and when i had the co2 it was fine.
have i got a dodgy bottle or do both bottles use totally diff regulators
also been told by a mate that he has been told by machine mart that there should not be a diff in the bottles and that it will work fine
if it was the case then surely then the both bottles will work with both gases with no other regulators needed for diff bottles
i hope someone can help before i go and pay out on anything else
