As mentioned above, a 180amp Inverter MMA (stick) welder would be your best option for that type of work
Why do you consider this a better option than a simple 180 amp transformer-based arc welder, please?
An inverter is relatively expensive and has hundreds of electronic components, any of which can blow and make it totally uneconomic to repair.
A transformer-based arc welder is dead simple with virtually nothing to go wrong, and costs peanuts. It will also make a fine job of welding heavier bits of metal.
 I suspect that the duty cycle of your welder is pretty low. I would also suspect that there are very few power settings (2 maybe) on your welder which would make it less versatile. I also suspect that it is very cheaply assembled. As you say yourself 'how can anyone have made anything?'. Well the answer is they made it for almost nothing so they can sell it for almost nothing. In my experience, you almost always get what you pay for.
) nor to pay someone to weld my Minis at £10-£15 per hour. I taught myself to weld thin bodywork (Minis, remember?) with an AC arc welder out of necessity. There's no way I would consider that now that I have a MIG (albeit one of the crappier ones).
