shenion
Tool Pack Rat
- Stone Mountain, GA USA
I saw this on the MIT videos posted earlier by eil and decided to make one:
Basically it is a bar turned to 1/2" then turned to a point. It is center-drilled then the end is cut off. A spring is inserted to hold the tip on.
You insert the tool in a chuck or collet adapter. The tip goes in a center-drilled hole or a punch mark. You use your fingers to feel if the tip is still aligned to the shaft. You can easliy feel an 0.002" offset.
Saw it first used on a drill press to make sure chuck is centered over punch marks. Then again on a mill.
Tried it on my lathe. worked well. I knew the tailstock was about 0.001" off. It showed up and I was able to adjust it out. The surprise was it showed my tail stock is about 0.002" low. Not sure how to adjust that out
