Bristolbulldog
- UK
I need to learn to tig, and I want to Re-skin the tailgate on my classic range rover and turf it into a locker.
So, I'm going to measure the width of the tailgate tomorrow, and that's how wide my brake press is going to be. I'm rarely going to be bedding heavy stuff as I'm more likely to cut and weld it.
I've just ordered up a rusty old rsj 4.5 meters long, 10." high, and 5.5" wide. I have no idea how thick the steel is, but I'm guessing 6mm+
I was going to go for the usual H press, use the rsj for the top and bottom of the actual press area (possibly put in some webs, or angle to limit bending) and then 6mm angle doubled up in some way to make the uprights.
I've got plenty of 6mm offcut plate to use on this if required as well.
I'm looking at putting in 6mm shelves, probably wedge re-enforced to lower the bottom of the press on, as opposed to the cut holes and bar, as I think with the little plasma I have on order, i won't be accurate enough with it. Whereas I can tack these tabs perfectly in place and get it spot on.
I'm a good mig welder, but terrible tig welder, and this to me seems like a good project to learn on.
I've got an r-tech 200A dc digital tig, with far too many settings on it, and it confuses the hell out of me even after reading the confusing manual. I can seem to set the amps, pre and post flow etc. I'm inclined to leave pulse alone, as that's confusing. I understand the principals, but they use slightly different terminology to guides on how to use pulse, so I can't figure exactly what's god settings,
