shenion
Tool Pack Rat
- Stone Mountain, GA USA
Have a B&S 12HP engine here. Funny story. This thing busted a connecting rod. I drained the oil: first 1/3 quart of black slime, then 2/3 quart of nice clean oil.
So, after it went "bang" because they never changed the oil and let it run low; they thought adding oil would magically weld the 12 pieces of the connecting rod back together and it would run
This is the second engine they blew up and is only 1.5 years old.
I bought it for parts, but the piston/sleeve is spotless. Counterbalance and main bearings look fine. So looks like it would only cost a new rod and some gaskets.
The old rod had destroyed itself. It did not chew up the crankshaft journal but there is a layer of aluminum that is "fused' to it.
I tried a brass brush and it did not do much. I trying to think of a way to get it off.
One idea is bead blasting it then polishing the journal. As the crank is hardened, I don't think that would hurt it.
Another idea is to heat it to lossen the aluminum. Do no want to risk annealing the crank.
Any ideas, maybe chemical, acids etc?
I do notice the part # for the rod has been superceded with a different part. Maybe they had issues
