Hi all,
My Butters 1800 AMT has an intermittent wire feed issue. Sometimes it feeds fine, other times the wire stops feeding.
It's not a wire tension/resistance issue, the wire dispenses and feeds fine. The tension on the feeder is ok, it's not slipping. It's either the motor or the driver PCB.
If I watch the feed drive pully I can see at times it doesn't turn, then sometimes it will work fine.
Does anyone know of a replacement motor/feed unit that fits the 1800 AMT?
Is there anything I can check on the PCB/test/replace?
Thanks,
J.
Thanks,
J.
