chevyman_de
Last year I built my welding table. Since I don't have the space for a permanent solution the table had to be foldable. A table and my truck won't fit into my garage at the same time. When not in use the table will fold up and be strapped to a wall. When “assembled” it is a rock-solid table that keeps up with standard design tables.
The plate is 600 x 1200 x 20 mm, the frame is 50 x 50 x 5 mm. Overall height is about 950 mm. Btw, do you prefer metric or imperoal sizes on this forum?
Wheels are vulcollan 125 mm, 500 kg dynamic load, 1.000 kg static load rated; mounting plates are 8 mm.
A 3 ton hydraulic ram from a cherry picker is used to lift the plate. The hinges are scratch built; the nitrited hinge pin is 25 mm diameter.
