GrahamGKD
Urghhh, was just doing a bit of TIG this afternoon - DC at around 45 amps. When I arced up I got a brief arc which then stopped followed by error E7 on the machine. I switched the machine off and back on and now it is completely dead - no displays lighting up - nothing.
I have tried another source of power.
I'm assuming I will have to bite the bullet and send it off for repair unless someone has suggestions of things I can try?
Edit1: It's a Lorch machine, by the way - I put the post under the Lorch section and then forgot to put Lorch in the title!
Edit2: Error E07 is some kind of internal power supply fault, apparently. I've tested for power at the switched side of the mains switch and have given the machine a good clean out but there is still no sign of life from it.
