W.olly
- Radcliffe, Manchester
Hi all, now after some debating over what to do with the roof on my Melos i have decided to go with the mild steel sheet option, it was either GRP, i decided a lot of faffing with that, and ally is to expensive at the minute. I can get 2x1 cover sheets for a tenner, not sure on the thickness yet but i am thinking 1.6mm will do, or 1mm.
This is the car i will be putting it on
Its not going to be easy to form the curves as all i have is lengths of 3x2 and G clamps to make sharp bend and curves will be either bent in small section bit by bit or the corner section cut and tacked/welded in place then filled to get a nice curve. Not sure on the finish yet, going with either black vinyl or paint, the decider will be how good it turns out as vinyl will hide a few sins.
So when SWMBO gets home i will shot off over to the steel stock holders and see if they have some cover sheets in. Not going to be easy as i am suffering with bloody tennis and a bit of golfers elbow after 12 years of dragging gas cylinders around on deliveries, but no rush so please bear with me if you are interested in watching.
wolly
wolly
