shenion
Tool Pack Rat
- Stone Mountain, GA USA
Slapped this together quickly. I used 1" conduit. Yes, it is zinc-plated and put out nasty fumes. I had a fan going and did grind most off first.
I made it as a test of dimensions. I have 3 bikes for it to fit. It fits my ZX6R perfectly. This is good as it has no center stand.
I had intended to just see if it fit on the different bikes and then build one out of stronger tube or box steel. But it is surprisingly strong. Just a little side-side wobble. I have added a foot to each vertical piece and that should keep it steady.
Only thing left is to make a U fork on the top. Will weld a 3" wide strip of flat steel to a smaller tube that fits inside the vertical tubes. The U will be offset so it can be turned in or out to cover my other bikes. (like jack stands have, that bent plate on top, but wider on one side.)
Here it is with the ZX6R ninja. Now needs a coat of Kawi green
Oh, total cost: $7 for a 10' pipe. The home supply has 4' 25mm steel box for $25! What a rip. Will be heading to a local metal recyclers to see about getting some supplies cheap.
