Wendelspanswick
After all this talk about cheap plasmas dying and me boasting about how my 5 year old CUT50 was still going strong I went to use it today and although the torch would trigger the air there was no cutting action.
I checked the consumables and for continuity in the torch and the return which were all OK.
I decided to whip the covers off and if I couldn't spot anything obvious I would get myself a new one as this one had earned its keep.
Covers off and I quickly spotted that a 1000uf 50V electrolytic capacitor on the top board had a horrible brown crust over it, I checked my junk box and found a new 1000uf cap but it was only 35V which I didn't want to risk using.
I went through my pile of old PCB's and found a 50V one but it was physically larger which meant I had to shave some plastic off the adjoining connectors, during which I time I managed to knock a trim pot off the board snapping the pins... aarrgghh!
I knew I had no spare trim pots but then it dawned on me that as the trimpot was already set all I had to do was substitute a resistor for the measured trim pot value.
I soldered the cap and resistor in and reconnected everything and it works!
For future reference here's a PIC of the offending board with the new cap and resistor soldered in and the offending cap on the bench.
