backpurge
There has been a bit of discussion on other threads around the effect of flow tube tube angle on flow rates and also how the angle of the flow tube will effect the accuracy of the recorded flow rate so I thought I would conduct a simple exercise to illustrate this
I fitted my digital flowmeter to the end of the welding torch then set the flow at around 10 ltr/min using the flow tube and hit the purge button on the welder
As you will see the flow tube is registering 10ltr/min and the actual flow measured on the digital meter is showing 7ltr/min
I then tilted the flow tube over by 45 degrees
You will see the reading on the flow tube has increased to around 11 1/2 to 12ltr/min as would be expected due to the ball bearing requiring less force to lift it but the measured flow at the torch remains the same. So this is showing the angle of the tube has a small effect on the accuracy of the reading on the flow tube but doesn't effect what is actually coming out of the end of the torch
![016675490c45ba81b398ce33835112cf_zpse6784ebd.jpg](http://i87.photobucket.com/albums/k141/bob-58/016675490c45ba81b398ce33835112cf_zpse6784ebd.jpg)
![e54ae54fedf058461edec632ad5f527e_zps0ac5d990.jpg](http://i87.photobucket.com/albums/k141/bob-58/e54ae54fedf058461edec632ad5f527e_zps0ac5d990.jpg)
