Hi All,
The last time I used my SIP handymig the wire feed stopped working, as I needed to finish the job I was doing I went and bought a different welder and this has sat in the corner of my garage waiting for me to do something with it.
I've stripped the cases off it to have a look, when the torch trigger is pressed the relay on the pcb clicks as I'd expect, I also used a 12v power probe to supply power direct to the wire feed motor and it works so the issue is the supply to the motor.
above is a picture of the pcb, all the joints on the back look in good condition and as I said the white relay in the top left corner clicks when the triger is pressed. I'm guessing the black tansformer in the centre of the pcb has failed but thought I'd check in here?
The label on the transformer seems to suggest it's 230v in and 12v out unit but every other post I've found online for sip units suggests the wire feed motor is a 24v unit?
I've also found some other posts about fitting a dedicated power supply to run the wire feed motor, If I was to do this would I still need to replace the transformer on the pcb or would the new power supply bypass this?
Thanks
Chris
Thanks
Chris
