malcolm
& Clementine the Cat
- Bedford UK
This thread links to a small selection of informative threads in the shielding gas forum and elsewhere. There's a lot more good stuff that can be found with the shielding gas forum search.
To suggest useful threads for the library use the thread rating system. Click "Rate Thread" and vote for the thread.
Gas price calculator
Gas price spreadsheet
An excel spreadsheet maintained by marknotgeorge compares shielding gas prices from a number of suppliers. Depending on your usage and location a hobby welder could save up to 80% on shielding gas.
Gas comparisons (mild steel MIG)
Gas comparison for DIY mild steel (on main site)
Comparison between CO2, Argon/CO2 mix, and pure Argon.
CO2 Thin Metal Warning
Beware when welding 1mm or less on low settings - CO2 can fail to maintain a workable arc.
Detailed comparison of percentages of Argon and CO2 (Shenion's website)
Shenion varies the gas mix at 10% intervals from 100% Argon to 100% CO2.
Wow! Argonshield
Member changes from CO2 to an argon/CO2 mix. Notices a difference.
Welding gas reference (main site)
A quick lookup by Omniata showing the composition of different BOC and Air Products gasses.
Weld faults due to shielding gas
Welds collapse in frothy heap
Includes photos of porous welds and one good one. Welding outdoors in the wind or poor flow from disposable regulator might have been the trouble.
Regulators
How to judge correct gas flow setting
If you only don't have a flow gauge on your regulator you'll need a peashooter to measure gas flow.
Freezing regulators on CO2
Some non-welding CO2 bottles suck up liquid from the bottom with a tube.
Gas Economiser (Argomiser/Argosaver) Photos of gas economisers and why Chinese regulators cause exprosions.
Disposable bottles
How long do they last?
Not very long at all. A 60L bottle running 10L/min would last for 6 minutes (1m of weld).
Connecting the welder to the regulator
How to fit and remove the plastic pipe.
Disposable regulator and gas bottle problems
Covers some bottle problems as well as regulator problems.
Safety
Shielding Gas Cylinder Safety
Woz's well researched post covering aspects of bottle identification, handling, use, disposal and many more dos and don'ts.
Transporting gas bottles
Rules and regulations for transporting bottles.
Use the right gas in the right cylinder
Some info about why not to fill a cylinder with a different gas.
How to fit a regulator
How to safely fit and set up a regulator on an industrial gas cylinder
Moderators feel free to edit this post to link to further threads.
Sorry, this thread is closed as it's an index thread, but feedback is appreciated about the idea of forum libraries.
Wow! Argonshield
Regulators
Disposable bottles
Safety
