hotponyshoes
- Somerset. Uk
I have an 18v 2ah power tool battery that was working fine.
I dropped it from a decent height and it was completely dead. No indicator light or anything.
I opened it up and found a break in a metal joining tab.
The cell at the damaged end was reading 0v the other's all about 3.7v or so.
I ordered one single new cell, fixed that and repaired the break in the metal strip.
Put it back together and put it into an led torch to "test" it.
Worked fine so I left it in the torch and used it until it went flat.
Then tried to recharge it. Charged fine for a couple of minutes then the charger shut down with a red error light.
Took the battery apart again.
The new cell I fitted was reading about 3.9v and the others all between 3.2v and 3.8v.
I did record the exact voltages if it matters?
I thought maybe the charger was detecting a cell imbalance?
So I tried running it flat in the torch again and recharging a few times. Seemed to help as each time the charger would run a bit longer but I couldn't get it to charge up past one indicator light so I gave up.
That was a couple of weeks ago.
Just opened it up to have another look at it.
I've now got voltage readings of 3.7v on the new cell. 3.7v on one of the original cells, 2.4v on another and 2 cells with 0v.
All cells are wired in series, so I'm not sure why 2 more seem to have died?
Any way to fix or test this?
Any reason why I have messed this up?
Should I have replaced all 5 cells together?
Or should I have disconnected each one and balanced charged them some how?
A genuine new battery is about £30 and this is the first time I've ever needed to try and repair one so I don't want to be spending a fortune on special chargers or anything
