Hey chaps,
I’m in a bit of a dilemma as to what to do. I have a Lotus Exige which needs both the rear and front clams re-sprayed due to a previous knock. The 3 options I have are; 1, body shop to spray the clams. 2. Use 2 pack paint 3. Use cellulose / water based paint.
My health is paramount. I do not want to risk damaging my health with any dangerous vapour. I already have an ABAC 3hp 200L air comp, Devilbiss GTI gun and a large garage. If I were to use 2 pack paint and an air fed mask how would I provide the air compressor with fresh air as that is also in the garage? Regarding option 3, paints4u offered me;
Acid #8 1K Etch Primer
AW Cellulose Ind. Primer Grey
BSB Industrial Colour
C10 1K Industrial Lacquer
How would you rate these products?
If I did go with the cellulose I would prefer to pay a premium for the best products. What would you consider?
Hi Again,
Yes the etch is designed for fibreglass and aluminium. I think you are
getting 2K and 2 pack mixed up. 2K is a basecoat paint (solvent or water
based) and is not toxic like 2pack. However the clear coat is usually 2
pack and therefore this is toxic and unsuitable for applying without an air
fed face mask. We should be able to find you a reasonable match to respray
your wheel(s).
Our waterbased paint is very easy to use and offers very similar performance
to the solvent based 2K paints. There are many different waterbased paints,
some good some quite poor.
HTH
Louise
How much roughly would it cost to for the 2 clams to be resprayed bearing in mind all the prep work would have been carried out by me and no masking is required?
Thanks,
Adrian
Hi Again,
your wheel(s).
HTH
Louise
Thanks,
Adrian
