hi there people
I was wondering can a base coat be applied straight over cured 2k clear.
or does it need to be re-primed as well
see, my trouble is, that I have recently just sprayed my car with 2k also using pearls and candy, all was well, I was on the last stretch when i went to mix up my last batch of pearl, turned around to get something to mix with and knocked them off the bench all over the flooro:
the candy pearl was mixed in with the clear coat.
I have had to order new pearls from the u.s, so by the time they get here the paint will be fully cured.
I will need to re-shoot the base again as i cant sand the clear without it being patchy and affecting the mica in the pearls but will i need to re-prime the car as well for proper adhesion or will blocking it with 600 be sufficient?
the car has a custom body kit with ALOT of detail and I'm kinda over sanding now, so if I could just go over the clear with base that would save me sanding it twice
on the plus side, my floor looks very pretty
