beneedle67
New Member
Hello to you all. Can anyone advise me - I am completely stuck.
I sprayed the rear quarter panels after welding repairs to the rear wheel arches. I used celly etching high build primer then celly metallic. Then finished with 2k Clear coat.
It all looked great but had a couple of runs in the clearcoat - nothing too disastrous I thought. I rubbed them down the next day with 600 then 1000
That is when the problems began. I went a little too far and went into the metallic. No problem I thought. Just go back over the metalic.
Well, it all wrinkled where I had feathered it. Okay, keep calm I thought - it clearly hasn't fully cured - must learn not to rush. Two days later and it still wrinkles. Okay, I thought. Simply lightly sand, feather then a light coat of primer then new metalic. (Too bad about the price of the paint, I thought.) No. Wrong again. The primer also wrinkles the feathered edges.
There must be a solution other than taking the whole lot off.
Can anyone advise. I would be very grateful.
Yours, Ben
Yours, Ben
