Jgguinness
New Member
- Durham
Hi all
Bought a compressor today, decent but cheap enough. Trouble is its a 3 phase motor.
Plate on the motor says 2.2kw output (so just under 3hp), RPM 2850.
Plate on the compressor says working pressure Lb/in sq 171, piston displacement 13cfm, motor output 3hp, max speed 1115rpm
Anyone know what single phase motor would be suitable? I've seen a 3hp motor in Machine Mart, 2 pole 3000rpm. Starter amps required 10-16. Shaft dia is 24mm which I think is slightly larger than the existing motor shaft. Would this be any good?
Kind regards
Jonny
Kind regards
Jonny
