Mr Fro
- Bury st Edmunds-ish
Alright dudes,
Been a while since I've posted but I've been lurking in the background...
Anyroad, I parted ways with my little ML10 and got my grubby mitts on a very nice Boley 4L which I've been running since the spring.
The previous owner used it for fiddly aerospace stuff so it only has a 1hp 3 phase motor running on a small VFD and I noticed the other day that it was really struggling when turning up a new 5 inch chuck backplate.
I was thinking to beef up the motor situation to 3kW with a 4kW VFD but I'm a bit in the dark about all that gubbins.
I've done some reading and have found some sources that state the VFD needs to be over specced in relation to the motor - how much exactly depends on the source of information...
In noddy terms, does a 3kW motor and 4kW VFD sound like a happy marriage and is there anything I should be aware of?
Most of the work I do is starts life as a few inches diameter and the milling work is probably the same although I have a 50mm shell mill I use occasionally which could probably use the extra power.
Cheers,
Fro
Cheers,
Fro
