Thanks for the kind replies.
The auction is Thursday. I'll update the amounts after. Yes the dinosaur was a bit of cutting but since it was with the plasma it wasn't to bad. It's not able to be dismantled since I'm the intent is for it to go into a garden to rust and get some colour.
Templates were printed on card stock then traced on steel and cut.
It was a great auction.
The triceratops went for $30CAD and the fairy for $13CAD plus i looks like I'll have some orders for various yard art projects coming in.
Are these being done freehand or by machine?
If freehand how are you transferring the image onto the sheet?
Have you tried printing the image onto paper and sticking it straight on using spraymount. cut straight through the paper and the metal.
Chunko'.
No you can do it with el plasma cutter.
I was completely sceptical when I was told about it.
Download the classic Che photo, use spray mount or similar to stick it down on the metal then as described cut around the lines.
Gets a bit smokey, make sure the paper is stuck well so it does not lift off.
Bonkers. Just dont tell anybody how you do it.
Have a go and report back
