DennisCA
- Finland
Figured I should write a little about masonry heaters. The general principle I gather is well known though, big massive heating place absorbs warmth from fire.
Masonry heaters are very common in Finland and Sweden and other colder countries too, but IMO their development into modernity went furthest in Finland. They are an effective way of using firewood. The principle is simple, the smoke from the fire is led through channels and forced to take the long way around and the heat is absorbed by the mass of the heater.
Mine is a modern heater and was built in 2014 along with the house. It's 1400kg and requierd the floor slab under it to be thicker and reinforced. It's located in the center of the house as well. That is almost always the case here, placing it against an exterior wall would lead to excessive heat loss.
It is not actually constructed from masonry though, it's made from pre-cast parts that is made from crushed olivine rock and high temperature mortar. It's a very heavy and heat resistant element compared to bricks. Still I think the classic brick heaters are still good and fine.
Construction, 2014
It arrived in parts
As did the lower parts of the chimney
The chimney base was built first
And before I knew it they had slapped up the heater and I wasn't able to take pictures of it in progress. I would've liked to have seen it go up in parts.
Anyway after that it was allowed to sit for a few weeks and dry out before I made the first fire, which was small.
Since then we've used it every winter to get additional heat for the house. And with todays electricity prices I am happy we have it despite having a heat pump.
After 7 years of use
Now here's a closer look after years of regular usage
Note the "slit" in front of the grate, it's a bit clogged with ash there but this is one of the more modern features of such a heater. It allows fresh air to flow up above the fire without having to pass through the flames which means it has more oxygen. When the fire gets going this means the flue gasses mix with the fresh air and are combusted again. Which equals more energy out of the wood and much less soot and pollution.
Looking into the firebox, the amount of soot here indicates the last fire wasn't optimal...
Looking upwards, there is a bit of a constriction to help the air mix with the flue gasses better. The flue gasses then pass down on the sides of the heater and then back up another passage to the chimney.
This picture should illustrate how it works better than I can explain:
How I fire the heater
This here is a typical load of firewood, about what I can carry in one arm. It's just pine, it's my own and it's free.
All the wood is oriented the same way and the fire is lit from above:
After 10-15 minutes the fire is going full bore. I close the chimney flue to half at this stage because I have such a bloody good draft in my chimney that if I don't I am loosing a lot of the heat. I don't like to adjust this bit on the intake because I want the fire to get the oxygen it needs. If you constrict the incoming air too much you will get incomplete combustion, resulting in soot and tar products and perhaps condensation in the chimney. Overall bad stuff.
I want a hot clean burn. Hence I adjust the chimney flue to reduce the draft, that way I know the fire gets as much oxygen as it needs. This takes testing and is a personal variable, but shutting it to half is a good rule for my house. It'll burn down in an hour like this, I shut the flue to 2/3rds when it's just coals and then close it when there are no more embers.
After that the heater will take 2-3 hours to get to maximum temperature and it will be warm all night and into the next day. I did two fires per day when it was really cold, now that's warm and hovering around 0C one per fire day is more than enough.
I think that is enough for now. I'd like to write about classical models later. I know mostly about finnish and swedish models.
Construction, 2014
It arrived in parts
