lotus_esprit_s1
- UK
Tried to use my Abac compressor today after replacing the head gasket last week and the pressure relief valve in the pipe from the low pressure side to the high pressure side is still constantly cracking off. I presumed this was due to head gasket failure / loose head bolts but it now has a new genuine head gasket and correctly torqued bolts. The head appeared in perfect condition when removed, along with bores / pistons etc (compressor has only been used occasionally)
The valve is rated to 4.5bar. The receiver is only reaching 4.5bar on it’s dial.
Any ideas?
Thanks!
Any ideas?
Thanks!
