I have an ABAC VT1080, which I believe goes under the name of SMART 1080.
Its a screw compressor.
I cant get it to go above 2.5bar.
I have had it apart and have found a problem with one of the parts (I think). The problem area appears to be inside the inlet body where the air is drawn in through. Inside this unit there is a small hole with a ball bearing in it and this is within a large spring loaded disc. I have been told that the disc should open at around 2 bar but its not. The shaft that it goes onto has signs of wear and it doesnt move freely.
Any advice would be helpfull and does anyone know where you can obtain spares and whether they are easy to get hold of.
