I have sprayed a few cars years ago with the old system before the new gravity fed guns, I have bought myself an Iwata gravity fed gun and I have a nice two cylinder compressor and a reg at the gun. My 29 year old Carina is Cellulose and I got the paint ok and some epoxy primer.
Now to the question, I have been doing the car a panel at a time as I am in my garage/shed, and have been learning the best settings for the pressure and fan, having done one side of the car I have reached a standard where the finish has only the very slightest orange peel if you look really close and it shines nice, but when it comes to large surfaces like the bonnet I am crap. I sprayed it exactly the same as the doors and wings but it had a very rough finish after the first two coats, I let it dry and rubbed it flat again with wet and dry and sprayed again with a lower setting on the needle, not a lot of paint going on at all and it took three coats to get a reasonable finish giving it about 15 minutes between coats but it still is a bit rough and has a worse orange peel than all the other spray work.
Is there a special technique for spraying large panels?
