Hi Guys
I have an old 50 litre sip compressors I use In my workshop mostly for painting and priming my steel fabrication work nothing fancy not spraying cars. I occasionally use some air tools and inflate tire ect. My current set up is just a 10ft peice of air hose and I gave to drag the compressors around everywhere and I get issues with condensation in the airlines. I want to fix the compressors in a fixed location and run outlets around my workshop and ideally fit some sort of water separater. Can I use regular 1/2 copper pipe or qualpex and if so what fittings/ adapters will I need to connect the two systems and can use just regular compression fittings will they hold air pressure. Any advice on how to do it safely and when to buy these fittings.
