I am out of my depth and am after some advice please.
I would like to buy a shot basting cabinet and compressor for DIY use. Looking at the Sealey web site
http://www.sealey.co.uk/PLPageBuild...8&analysiscode=&requiredresults=16&fulltext=1
what compressor do I need to run any of the SB970, 922 or 973 blast cabinets.
Sealey said 10cf SAC2203B for the SB970 and 30cm SAC62710B for the sb972 and 973 which looking at the instructions part of which I have copied below seems awfully high
SB970
3.1. Air supply
3.1.1. You will require an air pressure of 60-90psi, and an air flow of 5cfm to operate the unit efficiently.
3.1.2. WARNING! Ensure air supply is clean, dry and does not exceed 80psi
SB972
3.1.1 You will require an air pressure of 80psi, and an air volume of at least 5cfm to operate the unit efficiently.
3.1.2 WARNIN G! Ensure air supply is clean, dry and does not exceed 100psi
SB973
3.2.1 You will require an air pressure of 90psi, and an air volume of 15cfm max for operating the unit.
WARNING! Ensure air supply does not exceed 90psi
your advice appreciated
thank you
Dirk Pitt
MOD - Fixed link
SB970
3.1. Air supply
SB972
SB973
thank you
Dirk Pitt
MOD - Fixed link
