Sphinx
Once I'd prepared some steel to practice on and set everything up, I fired up the welder and gave it a go.
However...after I'd ruled out my novice skills being the cause for some terrible welds I realised there was no gas getting through, so after a bit of a fiddle (pipe had popped off inside the machine) it was time for take 2.
Here are the pics:
Reverse side:
At this point I was just playing around with various settings and found that I could get a decent enough (in my humble opinion) on either of the lowest settings with a variety of wire speeds by just adjusting my speed. I still find the lowest setting and going fairly slowly produces my neatest work.
Then I tried some butt welding and overlap welding. I find them both tricky at the moment but overlap joins are the hardest for me.
One of the biggest things I noticed was; it's all well and good getting some neat welds laid onto a single sheet of steel but things get much harder when you actually try and join things together lol
Here are the pics:
Reverse side:
