The advantage of going for 2 x 14 is that you can run them off 1-phase electric, you don't need to fill a big tank for a small job and if one breaks down you only lose 50% of your capacity.
1 x 28 would be more cost effective I would have thought.
If you need that volume of air then the large compressor with two pumps which is the one I believe you are referring to is the neatest although not cheapest option. It has staged start for the pumps and runs off a 40 amp supply.
