Hi guys I am new here and hope I get some useful help.
I got an air compressor (Fini 200 ltr) 3hp motor belt driven with this pump (http://www.ebay.co.uk/itm/Clarke-Co...t=UK_Hand_Tools_Equipment&hash=item2582f31b41) common for many air compressors.
The problem is that compressor is taking ages to fill up. The gauge seems to be stuck but eventually it fills up after an amount of time. The electric motor seems to heat up and many cases it operates the thermal switch.
Checked the check valve (no return valve) there is no air leak. it just leak few air on start-up when compressor tank is empty but stop after few seconds. I tried to turn wheel on compressor even when tank is full and it turns normally there is little hising sound of compression or suction.
Last week I was using an air saw this model ( http://www.ebay.co.uk/itm/Air-Body-...Air_Tools_and_Compressors&hash=item48596b0c22) and compressor could not stop working to fill up until the thermal switch got in.
I am suspecting that air compression is low or maybe stuck check valve restricting air in tank. What do you think?
Sorry for the long essay but tried to be specific as possible.
