What fittings do the air fed masks have for hose. I've been looking at low toxic breathing hose on eBay and it has pcl xf high flow hvlp type 25 fittings. I don't know what that means at all. Will it be ok ?
standard pcl fittings are 4.5mm bore . the xf series is 7.4mm bore the smaller of the 2 is well able to supply the air to your mask under pressure if u wanted to change them as the smaller ones are far cheaper
