out of curiosity have an air reciever on your hydrovane ?There is quite a bit of info on how to get clean dry air here. Scroll down and you will see mention of an oil and particle filter. If you put something like 'air line filter' into ebay you will see a few options. Is it oil you are having trouble with or water? I'm still looking for ways of getting dryer air for plasma cutting from my Hydrovane - it's going to be my workshop improvement project for the new year.
have u thought about making a heat exchanger basicaly a tube with a coiled copper pipe inside probably 22mm copper and a decent fan at the bottom i got some pictures and info if u want it emailing cant realy post on here without infringing copyrite it fits between the pump and the tank i made a simlar one for my shotblasting helmet airline supply to stop the hot air from comp . was a 5 gallon bucket of water with the air supply fed through a wound up copper coil in it to the helmet it worked a treatYes, it's one of these .
View attachment 25322have u thought about making a heat exchanger basicaly a tube with a coiled copper pipe inside probably 22mm copper and a decent fan at the bottom i got some pictures and info if u want it emailing cant realy post on here without infringing copyrite
