yoshie
- SW France
Hi, I have two compressors one has the usual drain that you unscrew a few turns to make the floor turn brown, due to the position of this compressor it's a bit of a PITA to drain so doesn't get done as often as it should.
Compressor number 2 has a drain valve that has some kind of pin sealing in it and the bottom of the pin has a cord attached, a pull on the cord opens the valve and when it's let go the valve seals, some times it takes a couple of tugs to get it to re-seal properly but it's a lot easier than crawling between the compressors.
Does anyone know where I could buy one of these valves? I've searched the net but no luck.
Thanks
Mike
Thanks
Mike
