diyhandyman
Hi, I'm new to the forum so sorry for any silly mistakes.
I recently just bought a 3HP belt driven compressor with a 90ltr tank from eBay, and all is good but i broke the regulator on it.
I needed a water trap anyway so i decided to buy a regulator/water trap all in one thing. I bought the Clarke FR1 air regulator.
I hooked it all up and stuff, but there is a big problem with it that the stock regulator on the compressor didn't have. When regulating the pressure, decreasing it to a value below the input pressure to the regulator does decrease the pressure, but then it builds back up to the input pressure. For example, if i have a 120PSI feed to the regulator, and i want 50PSI, the gauge on the regulator will read 50PSI when i increase the pressure from 0-50PSI, but if i leave it at 50PSI, which is what I want, it just fills the air line after the regulator, eventually providing the tool with the feed pressure of 120PSI.
When using the regulator with a spray gun, using the example figures above, it will give a 120PSI shot blast when initially pulling the trigger, but then it drops down to the regulated pressure.
It's as if the regulator is not regulating the pressure at all, more so it's just restricting the flow. The stock regulator on the compressor regulated the pressure correctly, however the Clarke FR1 is not working as it should.
Any ideas? I don't want to be using tools with initial high pressure shots as it will just mess up stuff, especially airbrushing.
Thank you for reading, and any answers. A video can be uploaded, if required.
