indy4x
- Pontypool, South Wales. UK
Am planning the new compressor install, not bought it yet but am getting all of the plumbing together to run lines around the garage.
I am looking to run 16mm plastic pipe from the proposed location of the compressor across the garage to where the airline hose reel is mounted. Will also have 16mm take offs for the plasma cutter and then a 12mm run to where the lathe & mill are situated.
I want to be able to remove the compressor easily so if needs be I can chuck it in the Disco and take it where it needs to go. Can't imagine this will happen very often but the quick disconnect option would be sensible.
I have been looking online and the biggest quick release couplings I can find are PCL100 series however the bore of the fitting is 10.3mm while the ID of the plasic pipe is 12mm.
Might seem like stupid question but am I better off going for a claw type coupling you see on hydrovane compressors or am I being overly fussy?
