Don't any of you be laughing I have been attempting to have a go today. Firstly,I was battling to stop the reel from unravelling. Next problem was the tip melting
It seems I'll have a further read on the tutorial section
aha,ok,thanks for thatLooks like you have to significantly increase wire feed superbad. Always the case when mig welding al/al
The bolt doesn't run up close to the reel,I'll have to put a nut onAs for reel unraveling, tighten up the mechanism bolt where you fit the spool, sounds like it is too slack?
yep,done thatPs, if using .8 wire, use a 1mm tip.
yep,done that
that's great advice,I'll do that next timeIts the wire speed - i melted three tips before i figured that one out Make it faster - mine is set near maximum for ally...
Like others have said, you need to have a feed which doesn't stick as well - keep the torch cable as straight as possible to stop the wire sticking in the liner.
No Malcolm,yes Malcolm I mean yes the tip is sticking out,because the shroud is nackered,the threaded part of the shroud has come away from the shroud,need a new oneIn the photo is the tip sticking out half an inch from the shroud? (Difficult to tell from that photo). If so then the wrong tip and/or shroud are fitted. Shroud should cover the contact tip.
hey my photographic skills is art,I could enter the Turner prize with such skillsIf your welding is anything like your photographic skills I'd throw the towel in lol
Only jesting
I only ask because if you are a novice, alu isn't the ideal material to learn on.
