chrisg3103
had a search and couldnt find anything. is there any reason aluminium cant be used to make spot welder arms?
actually did some maths
as an example a 16mm dia 500mm arm
copper arm
resistivity of 1.68x10-8
density of 8.96 g/cm3
would weigh 2.25kg and be rather expensive
aluminium arm
resitivity of 2.82x10-8
density of 2.7 g/cm3
to make the same resistance of the copper one aluminium would need to be 26mm dia. but would only weigh 1.1 kg and be a damn site cheaper! only disadvantage i can think of is it would heat up rather fast so would have a low duty cycle? would rather take lots of breaks than spend a few £100 i dont need to. possibly the mechanical propertys of aluminium, but at that thickness wouldnt the arm be stiffer than the copper one? any input from more experianced types appreciated
copper arm
aluminium arm
picking up some plasma cut parts tomorrow at my local welding place so will ask about the spot welding grease. will indeed do experiments first, need to replace about 90% of the panels on a mini pickup
