Hi. I'm new to welding with one weld under my belt. No, I didn't weld under my belt... nevermind, I'm new to this.
For my second ever welding project, I want to build an aluminum door/gate for the side of my house. It'll be a 3' x 6' (~1M x 2M) door built out of 1" (~25mm) square aluminum tubing, 1/8" (~3mm) wall and mounted on two hinges. The steel one there now has corroded off the hinges and needs replacing.
I have a small Lincoln 25 to 135A MIG welder that can also do aluminum with an optional kit and aluminum wire. I would have to buy this kit plus a bottle of Argon to do the job.
On the other side, I have read online that brazing with newer rod materials from the likes of DuraFix, HTS-2000 and others is a good substitute for MIG welding. For that I would have to buy a maap gas kit (propane is not hot enough?) and the brazing rods.
Considering my application, and assuming the initial investment in either method is about equal, which way should I go? Will brazing the gate be strong enough? Will it stand up to the elements? Being new to welding, how difficult will it be to learn each method?
Regards,
JR
Regards,
JR
