Kram
- Sussex
On the list to make is a tool post spindle for lathe to use small milling cutters, 12mm shaft. Ive been trying to find small taper roller bearings, "30201" seems to be a real size, 12 x 32, but no where stocks it. The next one up, 30202, 15 x 35 is common.
Instead Im wondering if angular contact bearings would be just as good. There seems a few options, single row, used opposed like taper rollers would be, with a nut on shaft to pre load them?
Or double row for the front bearing, looks like a better option? In that case would I use a plain ball bearing rear, or a single/double row AC?
3201 looks like the type I want?
