That's pretty much it, drilling bolt holes in steel beams etcOver what size range?
I guess your main use is drilling clearance holes for standard metric bolts, so do you want to be between M16 and M30 (four cutters would do, M16, M20, M24, M30). Do you need larger than this or smaller than this or a bigger range (e.g. M12 - M42). Standard length or extended length?
Same problem here m8, nearly everything is mail orderjust buy what ya need....sets are never cheap enough for a few to stand idle....
very diff here to buy them direct....
so I order from the local tool shop......yes they r Chinese but there's been no probs.....
If u want to buy British theres a firm in Yorkshire that make em, I'm told.....
...nearly everything is mail order
You should only really need 14mm, 18mm, 22mm for most jobs...
Well obviously at M10 and under you can use whatever jobber drill size that suits the job.At what diameter does 2mm oversize become unsuitable as a clearance hole? It is too much for M6 and too little for M30.
Ta, going to probably get the raptor 14-22mm set and a separate 26mm as not much dearer than buying 18,20 and 26mm separately, which is what one of my builder m8s reckons is most usedWell obviously at M10 and under you can use whatever jobber drill size that suits the job.
2mm oversize is pretty standard for structural steel holes M12 through to M24.
M30 you'd be at 3mm+ but how often does the average joe starting out with first magdrill need to use M30?
