Hi all,
I'm waiting for my new second-hand mig to arrive and I can't wait! I got a pretty good deal on an Aussie-built 25-170A heavy-duty unit (http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=4451572389) that should be good for panel work as well as the occasional heavy bit like towbars etc.
Never welded an inch in my life. I can solder OK when I really try...
I'm lucky enough to have a good mate who is an expert welder (currently employed tigging stainless food & dairy plant) so he will give me some training and help me get my welder set up properly.
I've got a trailer which I'm repairing and modifying a bit, so that's my maiden project. It's nothing particularly special so I won't cry too much over the early screw-ups. First task is to replace the floor (2.1mm checkerplate). I have some other little brackets and tricks to do, then hopefully I'll be brave enough to move on to some aluminium scrap before tackling an ali canopy frame for it.
I actually remember browsing the Aston V8 restoration site a while back, completely unrelated - I am fond of Astons and happened across it while searching for pictures. Cut to present day and I'm googling for MIG advice, and lo and behold I'm back at the same site! Good work Malcolm!
I have a quick question if anybody knows - the welder specs state that it can use 0.6-0.8mm steel wire, but for ali & stainless it only says 0.8mm. I've checked the manufacturer's info and it's the same. Does anyone know the reason for this? From what I've read here it would seem that 0.6mm is generally a better choice for thin stuff, so I'm wondering why I would be restricted to using the thicker 0.8mm wire in these materials?
